What year 225 ?
Yes and you can also. Via two ways.
Look on the other side of the motor for the decal that shows the month and year of manufacture.
Or go to the Yamaha US website at www.yamahaoutboards.com and open the parts catalog section. Type in the engine ID in the search box. 69KX1008615. Hit the enter button and it will take you directly to the parts catalog for your motor. You will then see the Yamaha production year.
This refers to Yamaha outboard motors that were distributed by Yamaha USA.
OK thank you. I know there’s a major concern with 225 an exhaust corrosion issues. Not sure if this year motor, a 2006 still suffers from this. Too bad because it’s a solid engine just a $3500 repair when needed.
No way of knowing for sure if the particular motor suffers from the mid section corrosion issue with lifting the block for an inspection. Some have it and some don't.
