Well...first off, I agree with racerone about running it in a tank with plenty of water in it....not muffs.<br><br>
<br><br>
But if it still won't piss there are a few possibilities:<br><br>
<br><br>
The tell tale passage might be blocked with debris/twigs/moss.<br><br>
<br><br>
You may have accidentally moved the drive key when putting the pump cover back on.<br><br>
<br><br>
You could have missed getting the water tube aligned with the block inlet. Did you inspect the grommet at the top if the tube?<br><br>
<br><br>
There might be old impeller pieces blocking the inlet to the block. Did you try backflushing the block and account for any pieces in there?<br><br>
<br><br>
Impeller pieces can also block the pump from priming as they tend to fall down below it when they shred. You can take off an intake screen and check whats in there.<br><br>
<br><br>
If the pump housing is damaged badly enough the pump might not prime even with a new impeller. If the impeller was in pieces then the cover/wiper cup should probably be replaced too.<br><br>
<br><br>
Good luck.
The housing and pump are brand new. Check my last post. It's up and pissing!:<)
