Hi, I have a 2001 Mercruiser IO with an Alpha drive. We’ve been having Trim issues so I replaced both of the Up and Down solenoids. The Up solenoid now works fine (both Trailer and Trim) but I don’t get the down control signal to the down solenoid (so it never closes). I can manually lower the trim shorting across the down solenoid to run the pump.
Trying to figure out how I can troubleshoot this…. (What could I have done that would effect the Down only?)
Thought about trying to find the engine connector that would have the trim signals from the throttle coming through it and see if I get it there, but not sure where it is located…
So, it’s time to ask the pros…
Thank you!
Thank you!
