wcannapolis
Good Afternoon! We just bought a 2007 Chris Craft Catalina 23 that has a 2007 Yamaha F250TXR outboard. Before buying, we had a mechanic check out the engine. Overall things looked good, but he noticed the hydraulic steering cylinder was leaking and also that the WP sensor module was corroded. His exact notes are below:
Two questions: I have seen two part numbers referenced for replacing the hydraulic steering cylinder:
HC5345-3
HC5358-3
Recommendations on which one to order?
Second, for the WP Sensor Module, would this be the correct part? https://www.simyamaha.com/f150-f250...d-link-water-pressure-sensor-69j-8a4l0-15-00/
Thank you!
HC5345-3
HC5358-3
Thank you!
