Hi all,
i have a BF45 honda she has been sitting for a couple years and i wanted to get her running to go out fishing, she always ran with no problems, so i charged up a battery i had and fired her up when i did i used water cups and hose for cooling but nothing was coming out pee tube. i ran it for a little bit but didnt want it to overheat after running for a bit i could tell it was getting hot and shut it down. i figured i needed to replace impeller anyway so i dropped lower end and sure enough it was shredded and looked a little burnt and melted. i cleaned everything out and ran water down from thermostat and water ran down tube into lower unit i had to unplug pee tube to get it to flow out that side but it does. i installed new Impeller/pump kit (was not honda OEM because was in a hurry to get before weekend) i fired her back up and same thing no water through pee tube so i loosened the thermostat housing with no thermostat in it and just air is blowing out. i have engine lowered into tub now just to make sure it has water. what could it be?
sorry for such a long post i just wanted you to get all the info
