dieselfuelonly
I just picked up this little Evinrude. I know very little about 2-stroke outboards and how they should run. Most of my experience as a mechanic is with big trucks. This one has no serial plate on it, someone in the identification section of the forum said it's a 6 to 8HP. No clue on the year, although the carb has a little white nylon looking piece that surrounds the main jet, it has a tube that looks like it goes up to the idle jet, looking through parts diagrams some years did and some years didn't have those. It wouldn't idle, I cleaned out the carb and adjusted the idle mixture screw, seems to be doing OK now. Idle speed seems low to me, if I crank the throttle all the way down it seems to dip down to 700ish rpm sometimes and will eventually stall. Should I bump it up a bit?
How about the knocking/shake when decelerating while in neutral, is this normal for a 2-stroke?
Tuning thoughts would be appreciated. Excited to get it out on the water soon and see how it really runs.
