First, check the No. 3 Fuse and make sure it is good.
If so, find the three-prong plug to your console T/T switch and unplug it. There will be a light blue wire (up), a light green wire (down) and a white wire with a black stripe. With battery on, and key switch on, check for 12 volts on the W/B wire. If 12 volts there, shunt that wire to either of the other wires and it should activate the T/T motor. If so, your switch is likely bad. So, remove it and clean the contacts, or replace it. If no 12 volts, then the power wire is probably broken or disconnected between there and the T/T relay.
