Johnson 35hp ID
don
" Could you help me on the yea
" Could you help me on the year of these motors?The guy that has them is trying to help me locate a lower unit for one that I have and I need to know if either will work? Thank you, Don "
" Sorry, it might help if I ga
" Sorry, it might help if I gave you the numbers
Johnson 35hp, serial# E5801306, model# J35ELCTS
Johnson 35hp, serial# E4689677, model# 35EL77C
Thanks again, Don "
" Thanks Rob, I checked and th
" Thanks Rob, I checked and the 35EL77C was on there but the number wasn't follwed by a C not sure what the C means?
And the J35ELCTS was not listed, so I am guessing that it is newer than 1979,thanks for any futher help,in advance Don "
" Rob,
35EL77C is a 35HP fr
" Rob,
35EL77C is a 35HP from 1977. Often the last letter of the model number represented a "batch" or "run" during the overall production run.
J35ELCTS is 35HP Johnson, electric start, 20" shaft, 1983. "
" Thank you so much,I wish I c
" Thank you so much,I wish I could be of some help on here but every time I see a question that I can answer you all have beat me to it,you guy's are the best, Don "
