1990 Evinrude, 40HP, Model VE40TLESR, Power Tilt/Trim question
Ernie84
[h=2]I have this motor on a pontoon boat that has been sitting in storage for nearly 2 years. After installing the battery, the Power tilt/trim initially worked to lift the motor all the way up. Then it seemed to have intermittent issues lifting the motor on later tries. Then after sitting a few days and trailering it to a location to work on a variety of things, the tilt/trim seems to work normally in both directions.
So is there any recommended maintenance to do on this assembly?
And is there a way to check the oil level in the tilt/trim assembly?
Please reply with any recommendations and maintenance/service instructions to do on this unit.Thanks much for your time and any help.
Ernie[/h]
