I have a 2006 Mag 350 Ser# OW389906. It has a Bravo III drive and is in a Crownline 240EX. Here is the issue:
New problem, never happened before. When I start it first time for the day, it will start right up and sit and idle for a couple minutes and die. After it warms up it cranks for about 5 to 10 seconds before it tries to start and finally starts and dies immediately. However, if you put it in neutral and give it a little gas, it will start and if you keep it revved up above idle, it will run all day. once back to idle it dies. It doesn't die like a switch is activated, it dies slowly if you know what I mean. Or, if when it starts and you put it in gear and give it gas, it will run fine all over the lake.
The oil pressure is at 70#, temp is 180, fuel full, voltage fine. Fresh water lake it's whole life in Lake Norfork in Arkansas.
Thanks for the help. This forum is a lifesaver.
