Hi everyone,
I have a 25hp johnson (TJ25ELEID) and its been running fine up until a couple weeks ago. The motor while cruising along started sputtering and died almost like it was out of gas, fuel was low but enough that it shouldve kept running. I managed to start it up a few times after but always had to give it a lot of throttle in order for it to start. If I brought throttle too low, it would die. I thought perhaps it was the carb and it just sucked something outta the fuel can when it was low. I pulled the carb off and took it apart and let it soak in berryman chem dip parts cleaner for a little over a day, took it out blew it out with an air compressor and put it back in the cleaner for another night (not my first rodeo lol) and blew it out again the next day. Then I rebuilt the carb and put it back on the motor. Motor wouldnt start at all now. Figured I didnt adjust the float properly, took it off and readjusted to allow more fuel in, still no start.
At this point I am starting to think I may have sheered the fly wheel key. I replaced it about a year ago when I had the fly wheel off and I never lapped it like I am now seeing is reccommended and am thinking something wonkey could be going on there. Thoughts? And does anyone happen to know the proper torque specs for that fly wheel nut on this engine?
Thanks!
Thanks!
