Cornallster
Hi,
Yesterday I did a bit of a service including the gearbox oil, impeller, spark plugs and finally the 4 stroke oil. It was all going well until I tried to tighten the plastic oil sump screw/plug.
The plug snapped and was stuck in situ. I was gentle with it using only a hand spanner on it but it happened all the same. I then had great difficulty in removing the stuck piece of plastic in the hole. During the process of trying to get it out a reasonably large piece of the old plastic plug has become stuck inside the sump past the thread. It is still visible and I can grab it with long nose pliers but it is big enough to be impossible to get out.
I have a few questions relating to this. Firstly any tips into how to get it out? Also does anyone know where to source a replacement (I can’t seem to find the part)? Finally if I can’t get it out and the whole or part of it remains how detrimental is that going to be for my engine?
My engine is a 9.9HP High Thrust Yamaha (Model FT9.9AE).
Any help with this is massively appreciated!
Thanks,
James
Thanks,
James
