junior4597
Hi all
Been reading a few post on this topic but thought I'd ask again to get a clear picture before I replace my older dizzy's. I'm looking to see if my Crusader 270's, circa 1987, will take a "standard LH rotation" distributor. My configuration setup is below and I will be headed over to the boat soon to check the dizzy rotation.
In reading some of the posts up here its clear that rotation differs depending upon your set up. What I'm trying to find out is is will my crusaders accept the "standard LH rotation" distributors. I am thinking yes even though my configuration consist of LH and RH rotation engines (obviously). The dizzy will still rotate the same way, right? Is there anything specific I should look for before I pull the trigger and purchase 2 LH rotation dizzy's?
And does anyone have an opinion of EST vs. mechanical advance? Which is "better"?
Thanks!
- Crusader 270's SBC
- Existing Mallory points dizzy (YL670AV)
- Straight shafts, borg and warner tranny (not v-drives)
Thanks!
