Hi,
I’ve got a 2006 Tohatsu 30hp EFI outboard (similar to Mercury). It’s cranking over but not firing. I’ve managed to trace the problem to no power being supplied to the fuel pump in the VST. The VST is filling with fuel and I wired a battery to the pins in the connector that leads to the electric fuel pump in the VST. It’s pumping fuel ok.
I suspect the wires come straight from the ECU, but am not certain.
I’m not too bad with mechanicals, but struggle with electrics. Any advice would be appreciated.
Thanks – Graham
Thanks – Graham
