MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 2 of 2
    Default 2002 Mercury 50 4 stroke carb float needles
    Good day. I have a 2002 Merc 50 4 stroke that I've got the carbs off for cleaning. On the float needle, there is a plastic insert on the top of the needle. It seems to me that the plastic tip should slide in and out of the top of the needle. On mine, these tips seem to be seized. This restricts the movement of the floats making the fuel level in the bowls very low. The result is the engine bogging badly on acceleration. My question; should these plastic tips be free to slide in and out of the needle or do I have another problem that I'm not seeing? Any help would be appreciated.
    Rod.
    Sep 2010
    24,202
    Default Re: 2002 Mercury 50 4 stroke carb float needles
    Take a very good look at the operation of the float and float valve.-----I think you might have problems elsewhere.
  1. 2002 mercury 50 hp carb float measurement
    By Wiemerib in forum Mercury Mariner Outboard Forum
    Last Post: 01-03-2020, 07:37 PM
  2. Stuck Float Needles! HELP
    By chickendeluxe in forum Yamaha Outboard Forum
    Last Post: 04-29-2018, 09:43 PM
  3. 2002 Mercury 40hp/2 stroke/2 cylinder/1 carb
    By Howmaster in forum Mercury Mariner Outboard Forum
    Last Post: 11-21-2016, 09:28 PM
  4. Importance of carb float settimg on Mariner 40 hp 2 str (2002)?
    By saoceallaigh in forum Mercury Mariner Outboard Forum
    Last Post: 07-25-2016, 02:55 PM
  5. Carb float height setting for Mariner 40 2002 2 str.
    Last Post: 07-24-2016, 06:52 AM
