Results 1 to 4 of 4
    Default Evinrude 15hp fuel pump rebuild - Chinese core?
    Gents,
    I have a 1988 Evinrude 15hp. Someone previously had installed a Chinese knock-off fuel pump on the motor. Cold, it would start / run fine. Run across the lake. After shut-down / fishing, restart would be a little tougher. third and fourth restart got progressively tougher. Upon examination, plugs were always very wet. Change plugs, problem went away on first start, but would then repeat the cycle. To shorten this up, I borrowed a factory fuel pump from a friend, installed it and all the problems went away. Motor runs great - idle - mid speed and high speed. I have read that these pumps were prone to fail, sometimes fairly quickly due to poor materials in the diaphragms. Two different local OB mechanics also seem to have had the same experiences with these knock-offs.
    So my question. Is the chinese knock-off core a good candidate to be used for a pump rebuild using OEM parts? Or, do I need to shop around for an OEM pump to rebuild? New OEM pumps seem to be quite pricey and I have no problem doing the rebuild work.
    I had a related issue a year ago. I rebuilt a carb on another similar motor with a Chinese based carb kit. Within a fairly short time, the gaskets had swollen and rendered the carb un-usable. This was the newer style 3 piece / plastic top / bottom carb. Installed a Sierra kit and problem solved. I'm making a correlation guess that the current problem is also a material issue within the pump.
    Sep 2010
    24,228
    Default Re: Evinrude 15hp fuel pump rebuild - Chinese core?
    You get what you pay for.------Your location ?-----If in Cansda-----evinrudeparts.ca -----might help you.
    Quote Originally Posted by racerone View Post
    Yep. Understand. Lesson learned a year ago. This pump was on the engine when purchased. I'm in the US. Upper midwest.
    Nov 2011
    tennessee
    5,484
    OEM parts wont fit the knockoffs
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  1. Fuel pump rebuild on 1977 Evinrude V4 85hp
    By Trapset in forum Johnson Evinrude Outboard Forum
    Last Post: 07-21-2021, 05:53 PM
  2. Evinrude e15rlcud fuel pump rebuild
    By Nayr in forum Johnson Evinrude Outboard Forum
    Last Post: 06-10-2020, 11:11 PM
  3. Fuel Pump 200 HP Year 2000 Evinrude Fitch - can I rebuild? Is this the problem?
    By JET OWEY in forum Johnson Evinrude Outboard Forum
    Last Post: 10-04-2014, 08:33 AM
  4. Evinrude 48 Fuel Pump Rebuild
    By wish2fish in forum Johnson Evinrude Outboard Forum
    Last Post: 09-11-2013, 11:48 AM
  5. Evinrude 1983 15hp fuel pump
    By jackman in forum Johnson Evinrude Outboard Forum
    Last Post: 06-18-2010, 02:00 PM
