Results 1 to 5 of 5
    Default Problems with Yamaha outboard
    Last time I boated it would sometimes be touch and go with power. When I got home I upgraded to a c227 filter and also put in brand new spark plugs. Next time I'm out it starts but wont stay on. Checked the fuel lines and I do think some water was getting in there before but not with the new filter. I live in rural Alaska and the only mechanic in town thinks it could be the carburetor. What do y'all think?
    Default Re: Problems with Yamaha outboard
    Is the model of the motor not known?
    2008 yamaha f40bejr is the model. Sorry I should have included that.
    If the problem occurred after the c227 filter was added I might want to remove that filter and see what happens.
    If the filter is not causing the problem then I would tend to agree with your mechanic. The carburetors on the F40B model are known to be very sensitive to any debris within. They have to be completely cleaned. Usually in a heated ultrasonic cleaner. Then the holes and passageways have to be verified as being free and clear. Particularly the accelerator pump circuitry.
    Some folks have had to install larger jets to get the motor to run well.
  1. Ordering Yamaha Parts for a 1985 8 HP Yamaha-Built Mariner 2-Stroke Outboard
    By SteveRI in forum Mercury Mariner Outboard Forum
    Last Post: 07-01-2020, 10:27 AM
  2. 1988 Yamaha 90HP-90ETLG OutBoard motor control cable problems (maybe)
    By GrantMcBay1 in forum Yamaha Outboard Forum
    Last Post: 04-15-2018, 04:14 PM
  3. 2009 50hp yamaha outboard water problems
    By pinksteriow in forum Yamaha Outboard Forum
    Last Post: 04-20-2015, 02:03 AM
  4. 2005 115hp Yamaha Outboard starting & idling problems
    By jamcat70 in forum Yamaha Outboard Forum
    Last Post: 04-21-2011, 09:13 AM
  5. 1992 4.3 Yamaha/Yamaha LU Shift Problems
    By Captain Jack Shallows in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 12-18-2010, 12:35 PM
