Click for Honda Manuals, Parts and Model Guides!
Results 1 to 4 of 4
  1. #1
    Default Bf225 timing belt/tensioner/idler automotive cross reference
    Heyy guys! I知 just starting to price out everything I need to do the timing belt on my 2005 BF225, along with some other deferred maintenance that needs to be completed. I was able to cross reference the timing belt itself to a BANDO TB286 for an 98-2002 Honda Accord, but does anyone know if any of the 2 idlers, or tensioner are also the same as what is used in an automobile Honda/Acura V6? I知 finding that the auto side of things has the parts at a much more reasonable price. Spark plugs especially.
  2. #2
    Default Re: Bf225 timing belt/tensioner/idler automotive cross reference
    The tensioner is definitely not the same as a Honda J series automotive tensioner because those are hydraulic tensioners and the outboard tensioner is not. The outboard tensioner pulley's alignment dowel is also located in a different spot. The larger idler pulley is very obviously different than the automotive version. The smaller idler pulley is close, so it may be the same.
    But I don't know that I'd try to go cheap on the timing system. Not something you really want to fail so I'd err to just getting the correct outboard parts.
    I would also recommend just getting the correct spark plugs. IZFR6F11. This is exactly what is specified for some Acuras, and they are cheap enough on Amazon. https://www.amazon.com/dp/B07XH3C14H...p_mob_ap_share
  3. #3
    Join Date
    Apr 2018
    Posts
    1,697
    As above, don't cheap out, it's not worth it, if things go wrong you will bend all your valves.
  4. #4
    Join Date
    Jul 2008
    Location
    Tauranga New Zealand
    Posts
    165
    I've found good prices for genuine Honda parts at Impex-Japan.
    Bob
Similar Threads
  1. Timing belt tensioner - should I be able to move it by hand?
    By metal-chicken in forum Honda Outboard Forum
    Last Post: 04-17-2018, 06:55 AM
  2. belt part number, or cross-reference?
    By eastcoastitalian in forum Mercruiser Sterndrive Forum
    Last Post: 01-08-2015, 10:24 AM
  3. Crusader v belt cross reference
    By jon_allen in forum Crusader Marine Engine Forum
    Last Post: 05-04-2013, 12:15 AM
  4. BF75A timing belt tensioner setting?
    By Cretster in forum Honda Outboard Forum
    Last Post: 10-03-2012, 07:26 PM
  5. AQ125A Timing belt Automotive Version
    By volvoken in forum Volvo Penta Gas Archive
    Last Post: 05-25-2009, 06:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
