I have a battery, points ignition system. 2 can coils, one for each cylinder. It seems I'm replacing one about every year in a climate with a very short boating season. Although the primary and secondary resistance readings are within spec, the coil cases crack and they operate intermittently before failing all together.
Not a big undertaking to replace them but they are expensive. Anyone have experience with failing can coils on this motor. Is there an aftermarket coil that's less expensive like from a tractor supply store?
