Rchristner
Purchased a 1978 Johnson 9.9 at an auction earlier this spring. The saga began with no spark so I used a multimeter to diagnose the powerpack. Replaced powerpack and started right up. But no water out the telltale.
Purchase impeller kit and replaced. Still no water. Removed power head to get at the common grommet issue and even though the grommet didn’t look half bad (appears to be fresh water only) replaced it. While the powerhead was off I blew air through everything and a large bug blew out of the block so I thought great that’s what the problem was it’ll for sure pee out the telltale now. Put it all back together, still no water. Removed thermostat and though it appeared to still function it was a bit crusty so I replaced. Removed lower unit and verified impeller housing slides onto copper water tube. Blew air from telltale tube and feel air coming out the lower unit where water would flow in. Thought I had it for sure.
still no water out the tell tale. I can feel a small amount of air and also some exhaust push through at idle.
My 4 year old daughter who I’ve been working on this project with says, “daddy I give up we’ll never get to go fishing” I really want to show her if you stick at something you can always get it figured out, but at my wits end on what to try next. Any suggestions?
