I have two 2019 Yamaha 200HP (inline 4) motors on my 2004 GW Gulfstream. It has about 120 hours. During last year's season, it has developed an annoying issue to blow the Main/PTT 20amp fuse intermittently. When is blows, the engine shuts down and the guage on the dash does as well. It is the port (left-hand) motor. The mechanic thought they had 'fixed', found a loose connection on the engine. Took it out, same problem again. It is at the mechanic again, and they found different loose connections (these are bolt/connections not plugs) at the engine (send me a video where). The two he found loose (in video) was the one without a cap (red dot on it) and the one directly to the right. Not loose that you can see it, but but if he touched the cable it moved). They are going to review all 12V connections. I am wondering if there may be another problem, like a short that has chafed in the circuit between the engine and the dashboard. Only thinking that since the motor is relatively new, but the wiring from the engine to the dash are original (as far as I can tell). Any ideas where to start troubleshooing if the loose connection does clear the issue?
Thanks in advance.
Len
Thanks in advance.
Len
