1977 15hp Evinrude 2stroke prop hub?
77' 2stroke
Forgive my inexperience with outboards. When running on the water (in foward gear), all of sudden I will lose acceleration almost totally as if the prop has stopped spinning and at the same the engine will rev loudly as if it were thrown into neutral. I let off the gas and try to accelerate again and things seem okay until it happens again, which doesn't take long.
After some light research I have found these are symptoms of a "spun hub". My question is/are: does my little 15hp have a hub assembly? Or is it called something else? Or does it have a different system that spins the prop? What parts do I need to remedy this problem?
15hp Evinrude 2 stroke - 1977 is the outboard I'm referring
Thanks for your time!
