Results 1 to 9 of 9
    Smile I Suspect???? a weak Battery??
    I have not run the engine in a few years. I ripped out and replaced cuddy cabin glass and wood. Now its time to start engine.
    I recharged battery, which sat on the shelf for approximately 2 years. When i remove the plugs the flywheel spins freely. With plugs in, and now with compression in the cylinders, its bogged down..? where should I go first....Battery or starter?
    The engine has sat up in the past. I find putting marvel mystery oil in the open cylinders, and the then spinning the flywheel without the plugs, loosens things up.
    Sep 2010
    24,032
    Default Re: I Suspect???? a weak Battery??
    Get the battery load tested.----Do you know what motor you are working on ? ----I don't
    Nov 2005
    Mt. Zion, Illinois,
    1,197
    Quote Originally Posted by racerone View Post
    Agreed. A load test is the only way to know if the battery is truly good. Many automatic chargers will show that a bad battery will take a charge, but it may be sulfated and have reduced cranking amp capacity.
    The engine is a J115TLCIM-1981.
    J115tlcim. 1981.
  6. #6
    Sep 2010
    24,032
    You MUST have a good battery and an inspected / good starter motor.-----If motor does not crank at about 250 RPM it will not have spark.-----And it will not start !-----Inspection / testing of the starter is easy in my opinion.
  7. #7
    How do I load test the battery? Can I take it to "Auto Zone" and have them perform the load test. Once i have a battery that I know is GOOD......How do I determine the RPMS? How do I inspect/test the starter?
  8. #8
    Sep 2010
    24,032
    Most garages / battery retailers will load test a battery in just minutes.----Often a free service , at least my local shop does.------2 bolts takes the starter apart.----Need a digital ohmmeter to check armature.
  9. #9
    I took the battery to be load tested and it was found to be in need of replacing. I purchased a new battery. The starter/flywheel spins faster; but I feel that it should still be tested. I feel I may have made a mistake years ago and purchased an aftermarket starter? UGGH. What is the best way to test the starter?
  1. Toahtsu MFS25B suspect cooling
    By mfs25b in forum Nissan Tohatsu Outboard Forum
    Last Post: 11-30-2018, 05:55 AM
  2. Alarm going off (suspect short)
    By riverjet88 in forum Mercury Mariner Outboard Forum
    Last Post: 07-25-2018, 11:48 PM
  3. Suspect oil colour
    By JoshNZ in forum Mercruiser Sterndrive Forum
    Last Post: 06-16-2016, 08:05 AM
  4. Pic of suspect gas
    By wildfrahm in forum Mercruiser Sterndrive Forum
    Last Post: 09-29-2011, 10:48 AM
  5. Installed Perko switch with single engine/two battery(cranking battery and house battery)
    By 1973 Browning Marine in forum Mercruiser Sterndrive Forum
    Last Post: 03-27-2011, 08:37 AM
