I have not run the engine in a few years. I ripped out and replaced cuddy cabin glass and wood. Now its time to start engine.
I recharged battery, which sat on the shelf for approximately 2 years. When i remove the plugs the flywheel spins freely. With plugs in, and now with compression in the cylinders, its bogged down..? where should I go first....Battery or starter?
The engine has sat up in the past. I find putting marvel mystery oil in the open cylinders, and the then spinning the flywheel without the plugs, loosens things up.
