Results 1 to 7 of 7
Thread: hard starting.
  1. #1
    Default hard starting.
    1991 Johnson J6REIA 6hp Outboard Motor
    Last week i had to load it back on the trailer because I could not get it started.
    I took it home and it started with some trouble in a bucket of water.
    When I can start it, it runs fine.
    Spark has no problem jumping a 3/8" gap Compression checked at 105 at top and 115 bottom.
    I try with choke on and then off with extended pauses. Incase I was flooding it. Plugs were wet when inspected. I finally got irritated and shot either in the carburetor throat and still no luck. Not even a sputter.
    What is your take?
    Taking it to the dump is not an option, at least not yet.
  2. #2
    Join Date
    Sep 2010
    Posts
    24,027
    Default Re: hard starting.
    How did it run for you last season ?-----If this motor sat for any length of time the carburetor may be gummed up.-----Is fuel fresh and mixed at 50:1 ?-----Does bulb on the hose go hard ?----Try giving it more throttle when pulling the rope.----Ignore marking on throttle grip.
  3. #3
    Join Date
    Apr 2010
    Posts
    5,426
    Try squirting some premix fuel in it once and see what happens.
  4. #4
    Try adjusting the float lower.
    Might be flooding.
  5. #5
    I am going to try some fresh fuel. I shot some in a cup earlier this spring and it looked and smelled fresh with just the right amount of quick popping bubbles. But it is last years. I did not want to deal with 5 gal of apparently good fuel.
    This was not the first use of the boat this year.
    I'll let you know results
    The carburetor will be my next focus.
  6. #6
    Join Date
    Apr 2010
    Posts
    5,426
    Did you ever try the pre-mix fuel in the carb ??
  7. #7
    I emptied the gas tank and much to my surprise water made its way into the gas even though I keep a cover on the boat when it's the yard.
    Thanks everybody.
Similar Threads
  1. 41p-a hard starting
    By pvbud in forum Volvo Penta Diesel
    Last Post: 04-23-2018, 03:56 PM
  2. Hard starting 85
    By ronward in forum Johnson Evinrude Outboard Forum
    Last Post: 06-01-2014, 09:50 PM
  3. Bf 40 hard starting
    By tunnelhull in forum Honda Outboard Forum
    Last Post: 08-07-2012, 10:25 PM
  4. MPI Hard Starting
    By 303Hound in forum Mercruiser Sterndrive Archive
    Last Post: 11-29-2007, 12:20 AM
  5. Hard starting 140 V4 OMC
    By Scott Bell in forum Outboard motors archive 2000-2004
    Last Post: 08-14-2002, 11:29 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
