Results 1 to 5 of 5
    Question 2006 5.7 GXI-GF Alternator Harness Connection
    Hi, I performed some service work last fall during winterizing. I'm now getting my 2006 Four Winns Funship deck boat with 5.7 GXI-GF gas engine ready for the season. I noticed a two wire alternator connector disconnected on the lower back side of it. I'd like to add, this connector only has one wire (purple) with the other one being cut off. I purchased this boat brand new and have always performed my own service work therefore, I know the wire was cut at the factory for some reason or another. Also, I've never had any alternator problems.
    My problem now is, I don't know if I somehow unintentionally unplugged it while winterizing last fall. I can't find a wiring diagram anywhere therefore, I would sincerely appreciate it if anyone could please confirm connection / disconnection and/or some pic's? Thanks, Ray
    I tried to upload some pic's but, was unable to for some reason....
    Jun 2008
    Island Heights, NJ,
    3,763
    Default Re: 2006 5.7 GXI-GF Alternator Harness Connection
    Is that the only electrical connection to the alternator???? ( other than 12 v neg via case)
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    Quote Originally Posted by sandkicker View Post
    Thanks for the help..... This cable is not the main Positive or Negative cable to the alternator. It's much smaller and is located near the bottom of the back side. I just tried to upload some pic's but, I'm unable to for some reason. However, I posted this in another forum (link below) that has the pic's. Thanks again, I sincerely appreciate your help. Ray
    https://www.thehulltruth.com/boating...l#post15586235
    Quote Originally Posted by Ray&Paula View Post
    I believe Purple (violet) is color coded to connect to ignition and/or instruments. A look at a marine standard wire color code chart may give you more info because the boat hasn't been messed with and was probably built to ABYC standards.
    Quote Originally Posted by Ramjamjungle View Post
    Thanks for your help..... Once I get my summerizing complete, I'll check my gauges with it disconnected and running. I'm not sure why they would have this connected to the alternator, but then again, I'm no mechanic....LOL. I'm also thinking that it may be for some option on other boats in which this may be just part of the harness. In return, leaving mine disconnected. I'm currently trying to find someone with the exact same year and make as my boat but, so far no luck. In addition, I'm looking for a wiring diagram specific to my VP 5.7GXI-GF as you suggested. Thanks again for your help and time, I sincerely appreciate it. ��
  1. Mercruiser Vessel View harness connection
    By lakeboater in forum Mercruiser Sterndrive Forum
    Last Post: 08-17-2020, 08:31 PM
  2. 1978 80 hp Main Harness Connection
    By Kubie in forum Mercury Mariner Outboard Forum
    Last Post: 07-18-2016, 03:39 PM
  3. Need help on wiring harness connection with control box
    By qhn in forum Yamaha Outboard Forum
    Last Post: 09-16-2009, 04:59 PM
  4. Alternator connection on 40 manual start
    By rldn in forum Yamaha Outboard Archive
    Last Post: 10-29-2008, 08:37 PM
  5. Alternator connection
    By richard_t in forum Mercury Mariner Outboard Archive
    Last Post: 04-30-2007, 09:04 PM
