Results 1 to 8 of 8
    Default 1988 Johnson 40 stator question:
    Motor: 1988 Johnson 40 J40TELCCS
    Question:
    Once the flywheel is pulled what all should I go ahead and replace while I’m in there?
    Reason/backstory:
    2020 - Bought the boat and motor. Rebuilt fuel pump, carbs, new fuel line and bulb (not the gray line), water pump, etc. Ran great
    2021 - noticed loss of power at beginning of season (4-5mph). Signs of bad powerhead adapter gasket with oily mess leaking down side of midsection and possibly water getting into a cylinder (bottom plug very clean). While on a trip the motor overheated and would die. Cool off and restart. Couldn’t get past 3300 rpm. Discovered the head gasket had failed and a chunk had broken off and blocked the water flow passages.
    Replaced head gasket
    New power pack and ignition coils and rectifier
    Didnt get a chance to test after that work.
    2022 - Same problem persists: can’t get over 3300rpm. Went ahead and rebuilt the carbs. Same issue. Tried a new power pack. Same issue. New plugs. Got good spark (jumps the 7/16” gap). So I’m thinking stator.
    Just want to make sure I change out what needs changed out with the flywheel removed.
    Thanks for the help.
    Sep 2010
    24,033
    Default Re: 1988 Johnson 40 stator question:
    Overheating ???----Do a compression test before you spend any more beer tokens !!----Post your test results.
    Quote Originally Posted by racerone View Post
    Thanks for the reply. I had typed this up once before but lost it and didn’t realize I forgot to mention the compression test the second time typing. 130psi in both cylinders.
    Quote Originally Posted by jdrake83 View Post
    I should add that when it overheated last year it definitely smelled like something got cooked. Hard to remember exactly what it smelled like…wasn’t exactly electrical smelling but it wasn’t normal exhaust odors. Makes me wonder if it was the epoxy or something on the stator coils. The guts under the flywheel is the last thing on the motor ignition system that isn’t new (after the overheating) so I figure it can’t hurt to swap the stuff out and go from there. Just want to know what all should get attention while the flywheel is off.
    Sep 2010
    24,033
    I had a motor overheat once.-----I replaced entire stator and it worked great after that.
  6. #6
    That’s good to hear. Not that our weather in central IL has been prime fishing weather but it’s been very frustrating when we get a rare good one and I’m working on a boat motor instead of being on the lake.
    So to my question: while the flywheel is off what should get replaced? lubed? etc.
    Cheers!
  7. #7
    Dec 2012
    newport news, va
    315
    three thing under flywheel, stator for charging battery, charge coil and ignition sensor, over the years had 2 bad charge coils, any black or brown goo under them, change them. along time ago , i had over heat problem, had 140 compression, did all your doing, finally removed head and found head gasket problem, good news removing head easier then changing thermostat
  8. #8
    Quote Originally Posted by scalhoun506 View Post
    Thanks for the reply. Sounds like we did the same stuff but in reverse order. I had actually changed the thermostat already when I got the motor since I wasn’t sure how old it was and I figured it wouldn’t hurt. Definitely a pain on this motor compared to later years. I’ve just never messed with anything under the flywheel so that’s helpful. Thanks!
  1. 1988 Johnson Remote Control (0397184) with 1988 Johnson J20ECCA Question
    By emilkob in forum Johnson Evinrude Outboard Forum
    Last Post: 05-04-2017, 07:01 AM
  2. Stator voltage for 1988 Johnson 90 HP V4
    By CarMech1969 in forum Johnson Evinrude Outboard Forum
    Last Post: 10-12-2016, 10:05 PM
  3. 79 Johnson 115 stator question
    By 78 Mark Twain in forum Johnson Evinrude Outboard Forum
    Last Post: 04-11-2012, 09:26 PM
  4. Question about stator wiring on Johnson/Evinrude 90hp motor
    By Roxanne Holton Geller in forum Johnson Evinrude Outboard Forum
    Last Post: 06-14-2011, 07:58 PM
  5. 1988 Johnson 225 no power stator
    By Ste in forum Johnson Evinrude Outboard Archive
    Last Post: 12-20-2003, 07:23 PM
