So I removed the flywheel and replaced one damaged magnet and epoxied two others that were intact but loose.
I set the pointer to the TDC mark on the flywheel before pulling it. If I put the flywheel back on exactly as it was do I need to do a link & sync? Or adjust the timing? Can I at least start it to see if it's charging again? Thanks.
