Today was one of my weirdest sessions yet - but I'm calling it a small miracle...
Since I didn't have a tub big enough to submerge my LU up to the A-V plate, I dropped my LU again & hooked my garden hose directly to the water tube & started it up - the port side manifold at the temp sensor stayed about the same temp as my well water - about 55* - the starboard manifold went straight up to 185*, the alarm went off & then it shut down - thinking I might learn something about how my sensors were functioning, I switched them around & started it up again - this time, neither manifold went above 70* & it never went into alarm - I then put the thermostats back in & started it back up with the hose still attached - both manifolds never went above 130* & it still never over heated!
I realize it doesn't make sense to think that just swapping my temp sensors around would fix my overheating problem - I'm guessing that the direct flushing I gave the motor cleared a blockage? Anyway, I'm confident enough that my pump is working properly, that I'm going to launch her & see what happens...
If the saga continues, I'll give an update - thank you all for your valuable insights - I hope I have an opportunity to help someone else out in the future - Happy Trails!
