I have twin BF225 on an everglades, was out fishing yesterday both engines were running I went to go move to make another drift was just after getting on plane i lost 1 engine no alarm or anything. I tried to restart turned over but had nothing, I removed cowling the LP fuel filter canister appeared to have a little bit of air 3/4 full of fuel, I pumped it back up with primer ball, gets hard, tried to start still nothing. Tried starting will pumping ball still nothing. When you cycle the key HP fuel pump does come one, It doesn't sound as healthy as my engine that works has a different noise to it when it cycles on. Not sure if its always sounded like that or that's new never listened that closely in the past. I ran 3 hours at 8 knots on 1 engine only have 1 tank, don't think fuel is the issue, all new Recors, LP and HP filters were just done engines have less then 6 hours since those where done. I didn't drain the VST Tanks. Any suggestions or help would be greatly appreciated Thank You!
