Hi, i have a mariner 60hp 1989 3 cylinder with 2 carbs . Worked fine for three years. Good compression. One day i fired it up on land with water hose connected. I was gonna lean the mixture out by turning the screws out. The engine was running very high rpm thats why. When i got it in a satisfactory idle rpm i turned the engine off and called it night. The next day, on land with water, it wouldnt start just a small pop in exhaust and smoke out of both carbs once. still good compression.Cleaned carbs , good spark, the engine will run for a few seconds with starter fluid. Fuel comes up to the carbs but wont get in to the cylinders. What could be the problem? the float level is correct. I need to get this on water as my son love the boat life , he cant wait.
