Results 1 to 3 of 3
  1. #1
    Default 4.3 mercruiser with alpha 1 gen 2. High RPM low power.
    Took my boat out for the first time this season. Ran great for a couple hours but after a couple runs at tubing the boat wouldn’t go above 10 mph. The RPM at full throttle is around 4500-5000rpm like normal but is only going 10pmh. I replaced the engine coupler last year after it completely burnt out and boat wouldn’t go anywhere. Wondering if my prop is slipping or if something else is going on. Planning on taking off the sterndrive to inspect the engine coupler later. Any other ideas on what could be going on?
  2. #2
    Join Date
    May 2010
    Location
    DC Burbs/Maryland Eastern Shore
    Posts
    2,390
    Default Re: 4.3 mercruiser with alpha 1 gen 2. High RPM low power.
    Sure. You shredded the splines on something. You burned up another coupler. Your prop hub failed. You broke the blades off your prop. Um, let's think, what else? Maybe the trailer is still attached? Dunno but sounds expensive.
    Practicing the ancient art of ren-ching
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    9,142
    I'd check the prop first...if the coupler was gone, I'd think you smell it in short order with that much slip...
Similar Threads
  1. Tight steering on Mercruiser v8 Alpha with power assist
    By jon_allen in forum Mercruiser Sterndrive Forum
    Last Post: 11-05-2021, 05:07 PM
  2. Mercruiser Alpha One High pitched squealing sound
    By k4rrc9 in forum Mercruiser Sterndrive Forum
    Last Post: 08-04-2020, 02:40 PM
  3. High RPMs but no power Mercruiser 4.3 Alpha 1 Drive
    By larsolr in forum Mercruiser Sterndrive Forum
    Last Post: 08-01-2018, 01:13 AM
  4. 93 Mercruiser 5.0L Alpha has no power
    By KH1975 in forum Mercruiser Sterndrive Forum
    Last Post: 07-04-2016, 10:02 PM
  5. 96 Bayliner 30 mercruiser loss of power high RPMbs
    By gsong in forum Mercruiser Sterndrive Archive
    Last Post: 07-16-2009, 10:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
