5.0 mpi will idle all day at 1000, drop it to 800 it will idle happily then stumble to near stall then pick back up to 800. There is no pattern to it, sometimes happy then not. New IAC valve. Showing no codes. Cheers
One item that frequently comes up with mpi is the failure rate of the crab style distributor cap. Might be worth looking at or replacing if an issue is causing the ecu to move the advance around at idle
Thanks Dieter, I will put that on the list. Its a mates boat .,I am going down on Tuesday have a look at it. The engine was just out of it for starter repair and other repairs. Could an ground or wiring issue be a cause?
Thanks Chris and appreciate your time,The IAC was supplied and fitted by the last Tech. I will read up on reindexing and give it a go.
