MY 98 Chaparral is STUCK IN FORWARD - it happened mid season last year. I went to slow down, and noticed we were still in Forward Gear. Oddly, the boat will start right up (QuickSiler 3000, has to be in "neutral" even though it's actually IN GEAR) and drive and perform perfectly (assuming you don't need neutral or reverse!) I can pull into my slip by shutting the motor off and on as needed. It will idle in, but is IN FORWARD GEAR. Shifter is easy to move - everything "Feels" fine. I opened the back of the outdrive, cable is connected to the shift arm, and it has some range of motion, just not enough to engage Neutral or Reverse.
Has anyone heard of, or had this issue?
thank you!
mike
thank you!
mike
