Mty Detroit v12 600kw turbo diesel солярка в масле
KirillMaimeskyl
Ребята
подскажите попадает в масло солярка!!! Какие могут быть причины? Подскажите варианты, что может быть?
Re: Mty Detroit v12 600kw turbo diesel солярка в масле
The fuel pump is mounted to the blower housing. It is driven by one of the rotors. The rotor bearing is lubricated by engine oil. If the fuel pump seal fails, pressurized fuel is sprayed into the blower housing and drains to the oil sump. The fuel pump has 2 seals. You can buy a rebuild kit for the pump that includes all internal parts including seals, or a rebuilt pump.
