Here is a quote from an earlier post, what do you think?
"When you idle it down and lean the low speed needle, does it "sneeze" on you? What's your mixing ratio? I have a dozen of these 9.5's around. Love 'em. I mix 64:1 on Amsoil Saber, or 100:1 Pre Mix Amsoil, but mixed at 64:1. Make sure crankshaft seals are good. If the seal will suck air, it will cause the motor to "sneeze" as well. Usually the result of ethanol fuel use. This motor uses rubber composition crank seals both top and bottom. Upper seal is most often the first failure. As Racer has mentioned in other posts, the seal will also spit out oil/fuel mix, and you will have signs of oil under the flywheel and often spilling on the block".
Quote from Brupp:
"I just went through the same thing this last summer with one of those motors. I did all of the same things, carburetor kit, new spark plugs, tune-up kit, impeller, lower unit seals. The whole 9 yards. I also had to do a fuel pump overhaul as the diaphragms were rock hard and the check valves were shot as they wouldn't seal properly. After I did all of that it would start up and run 100% better than when I first got it. But I had issues at idle it wouldn't idle smooth and would cough and sneeze and then die out. If I richened it up it would no longer cough and sneeze but I couldn't get it to idle down low. So then I pulled the power head off to check the crankshaft seals. There was no oil residue around the top crankshaft seal and both of them felt nice and soft and look like they were making a good seal around the crankshaft. But I changed them anyways being I was that far into it and put the whole works back together. Then I took it back out on the lake and tried it out. That is one of the nicest idling motors I have ever used! It idles down just as nice as my dad's 1959 Evinrude 3 horsepower. It will idle down so low and so smooth the boat doesn't hardly move in the water. You can barely hear it running. Not says the seals are shot, but they will be eventually.. just my $0.02...."
