Results 1 to 3 of 3
    Apr 2019
    Arizona
    121
    Default Damage to Deck and Topside Trim on 1975 Sea Ray
    My first reaction to the weathering of the trim and deck on this Sea Ray was that a good portion of the wood needed to be lightly sanded and treated with a coat of thinned epoxy. The hatches on the topside of the bow appear to be very damaged and weathered and will need to be replaced. The hatch in the middle of the deck has lost a supporting brace of some kind. The local boat shop in Arizona has mentioned using Teak wood for some of the repair.Click image for larger version.
ID:	28249Click image for larger version.
ID:	28250Click image for larger version.
    Dec 2006
    Greenfield Me. USA
    6,286
    Default Re: Damage to Deck and Topside Trim on 1975 Sea Ray
    Ayuh,....... As rotten as that deck is,.....
    I'm guessin' the transom, 'n stringers are too,.....
    Jun 2021
    Bowman, Georgia
    20
    Run forest run!
  1. No power topside, only below deck in 1985 Celebrity 225V
    By bsorge in forum OMC Sterndrive and Inboard Forum
    Last Post: 05-23-2020, 02:45 PM
  2. relocate start/house batterys (two) from aft. deck to forth deck.
    By TheBrain in forum Johnson Evinrude Outboard Forum
    Last Post: 08-26-2017, 10:30 PM
  3. Deck Damage?
    By jrnichols in forum Boat Hull, Deck and Transom Repair
    Last Post: 08-01-2011, 08:21 PM
  4. Deck / Railing damage?
    By jrnichols in forum Boat Hardware
    Last Post: 08-01-2011, 08:19 PM
  5. DT 115 LWR TRIM ACTUATOR DAMAGE
    By fjs in forum Suzuki Outboard Forum
    Last Post: 06-22-2009, 09:33 AM
