Gday all
Weirdest thing. I am blowing the 20amp fuse near the starter solenoid everytime I crank the engine for 2 seconds. Cranking obviously then stops when the fuse blows. Fuse is ok with ignition on or off and with choke active. Fuse does not blow instant I start to crank, but blows after 2 seconds of cranking every time. Also if I bridge directly from +ve battery to active on the starter solenoid (replicating the starter switch bypassing the fuse) then can get the motor cranking and running, but will blow fuse in 30 seconds or so.
perplexed.
perplexed.
