briansthomas
i have a 30 hp mariner that i believe is from 1979 - model 30M 689 S 014793
The engine has 120 psi cold compression and it has spark when plugs are grounded to block. The engine will not fire at all even with starting fluid in cylinder or carb. The engine looks like it is very low hours with zero corrosion anyplace. I cant seem to get it started for the life of me - wont even fire.
It has the type of coils where both plugs fire from 1 coil - i have not changed the plugs but i cleaned them and they look in very good shape.
Has anyone seen where the key under the flywheel sheers or moves and the timing might be off?
thx in advance for your help!!
