Hello Fellow Outboard Church Members.
Long time lurker, but I finally needed to ask some questions. I have a new to me 1982 25hp Mercury on my 16 foot Jon boat. This Motor came to me not running but with 115 psi on both cylinders and being told it needed a carb cleaning.... LOL oooh boy.
I have had the carb apart 4 times, I have rodded, soaked, and used compressed air to blow out all the passages. I know that all the passages are cleaned and I even bought a Mercury shop manual to be thorough.
But here is my problem.
Motor will fire up first or second pull of the cord and will idle for about 5 seconds with the choke on. then there will be a cough and the motor will sputter and die....
If you fire up the motor on the choke and then play with the butterfly roller on the throttle cam the motor will run at approximately 1500 rpms for as long as you wish... it will Rev, it will return to 1500 rpms... but don't ask it to idle... as soon as it goes towards idling, there is a PUFF out of the carburetor and then death...
I have fresh plugs, I have a rebuilt carb, I have visually looked at the reeds and they appear to be closed but the "puff" makes me think they may be bent or broken...
So I have bought new reeds, bought new reed cage gaskets and I purchased the reed cage rubber seal that separates the two cylinders.
Does anyone have any pointers? For the life of me I cannot find a pilot jet like a normal carburetor and the Shop manual does not mention one, So I have blown out every passage I can Find.
I have no doubt this motor could be a fun little motor if I could ever get the darn thing off the dock. My duck season and Deer season are being hammered by this little motor!
