Prop Replacement
RRConboy
I have a 17' aluminum bass boat, 1990 60HP Evinrude Tracker. Came with a 13.75 x 15 aluminum prop. Very satisfactory performance. If I replace it with an aluminum 12.5 x 15 will I be sorry. What performance am I losing?
Doing that makes no sense.-----Are you sure the 12.5" is for a 3 cylinder motor ??----Spline count the same?---Part # of this 12.5 X15" prop.----Where did you find this 12.5" diameter prop ?
racerone: Thank you so much. I apologize for taking your time, as my original search was a big error. I searched SOLAS (on the MarineEngine opening screen after a rec from a Dangar video) then proceeded to pick the WRONG YEAR. The choices for the correct year, for 60HP, 3 cylinders ,13-spine, do include a 13.5 x 15, aluminum, 3-blade. Problem solved. If I may ask, do you have an opinion on SOLAS, or do you prefer another supplier? Their $132.76 price seems very reasonable.
