Click for Crusader parts and manuals!
Results 1 to 15 of 15
    Nov 2021
    Blackwood New Jersey
    8
    Default Crusader 454XL-TB Starting/running problem
    I have twin 1996 454XL-TB Crusaders with approx. 1800 hours. Tune-ups, oil, filters are on a regular schedule. Problem: Starboard engine when up to running temperature, will start, then the RPM's will fall off till it stalls and will do that several times without idling. Sometimes after several tries, it will say running. Nothing shows out of spec on the computer and mechanical vacuum read 15 inch steady when idling at 650-670 RPM. Timing set 10 BTDC, gas pump pressure is 20 LBS running and it operates upon start with 2 second prime. I can hard throttle it with excellent response. After starting cold, it runs great, it preforms excellent through all RPM ranges on the water. What I have done to correct,(all parts are Crusader purchased) replaced: Knock sensor, Gas pump Relay, Starter solenoid, Temperature sensor, MAB module and vacuum hose, distributor Mag pickup and Ignition Module, used two new electric gas pumps, gas filter base and shutoff valve, gas main supply line to tank, fresh gas 90 gallons, switched to generator gas pickup port on tank and returned to engine port, swapped TB units and ECM from port engine that ran good and no change with swapping these units. So I'm stomped. My wife and I are 71, so we need this engine to be trustworthy. We do a lot of on water local anchoring in the Barnegat bay. Local marine mechanics are impossible to get available and I did try!! Any suggestions would be appreciated.
    Sep 2008
    Maryland - USA
    9,023
    Default Re: Crusader 454XL-TB Starting/running problem
    is the fuel pressure steady when the issue occurs - the ECU doesn't monitor it - ?
    Have you checked the cap and rotor to ensure they are in good shape?
    may also try swapping the ignition coils as it sounds like most other likely subjects have be swapped between engines or renewed...
    also, please clarify (operating conditions) when your issue occurs...I'm thinking after warmed up and running for a while, then Stbd engine RPMs fall off and eventual engine stalls...
    Nov 2021
    8
    Quote Originally Posted by makomark View Post
    n
    The cap, rotor, plugs and plug wires in good condition replaced 2 years ago. Ignition coil is new (missed that earlier). Sea trails are excellent in all sea conditions, engine maintains any set RPM which I change anywhere from 2200 to 3200 (cruse RPM) to as high of 3800 and we stay on water for at least 1 hour or more. Coming into the marina requires idle for 12-15 minutes with stable RPM. Once in the slip, it will idle as long as needed, doesn't stall and RPM is stable. Once turned off for a short time, then I have the problem with restart. I have noticed unstable fuel pressure during restart but doesn't drop below 14 pounds and maintains 20 pounds when running. That's why I stated two new fuel pumps thinking the first one was defective. Also note running temperature has been verified normal and oil pressure excellent at all RPM ranges. Also checked for anti-siphon valve which I didn't find in fuel system. All fitting in good condition. ECU computer data only shows fuel rate, not pressure. I use a remote fuel pressure test gauge for pressure reading, Thanks for trying to help, I'm
    at a loss!
    Last edited by Captfredsr; 11-19-2021 at 07:41 PM. Reason: missed important information
    Sep 2008
    Maryland - USA
    9,023
    The fuel flow is a calculated value, not measured, so take it with a grain.
    What you described this time around is a hard restart once warm, with a short soak time....
    On the anti-syphon valves, they look just like hose barbs...Unless your hull is ancient or off-brand, I'd bet they are on top of the tank. That said, I can't say I've ever seen them cause what you are describing.
    can you open the hatch once you shut off the engine? do you 'cool' the engine before you shut it off (fast idle, in N, and let the blower(s) run)?
    How long has this been happening?
    Apr 2018
    NW chicago area
    22
    15 inches of vacuum seems a little low to me.Check for vacuum leaks.If none are found try advancing the throttle slightly when it wont stay running and see if that helps.If it does check your tps setting and base idle.
  6. #6
    Nov 2021
    8
    Quote Originally Posted by stach454 View Post
    I'll recheck for vacuum leaks. TB gasket is new due to the switching it from the port engine. May need to pull of intake manifold to take a chance on a gasket problem that may be internal. I have tried slightly advancing the throttle but RPM still continues to drop off. TPS volt values are in range, QUESTION: how to check base idle? Maybe by disconnecting ECU connected to the TPS?
  7. #7
    Nov 2021
    8
    Reference "flow rate" Something I would have to test for hopefully without installing a Flow Meter" It can sit for a week and start multiple times without an issue. I removed all fitting which are threaded up to the elbow at the tank, ran thin plastic line through till I hit fuel, so no Anti-syphon valve. My fuel line engine to tank is Aeroquip #6 w/ screw on fittings (all new) no barb fitting. Temperature without load raises normally to about 160-165 deg. and still starts most of the time, once underway temperature stays around 170-175, the problem comes back yet temperature remains 160-165. Yes, I turn on the bilge blowers as soon as I start my cool-down run bringing the RPM's down slowly from higher RPM's or/and anytime I am at an idle coming into the dock or maneuvering. Blowers stay on for about 20-30 minutes once the engines are shut down. I can open the hatch if needed but the couch is hinged above it, so I normally close it anytime underway for safety. Could reinforced it if necessary to keep it open. How long? Problem started July 5 this year, yet ran fine till then. We launched it March 15 from winter haul out. I won't forget that date because that's how long I been fighting this problem. We've owned the boat since 2009 without any engine problems just normal maintenance.
  8. #8
    Apr 2018
    NW chicago area
    22
    If it still stalls when starting hot with the throttle advanced its probably not a base idle adjustment.You can check it if you want just google gm tbi idle adjustment its the same system that is on gm trucks.Compare the vacuum reading on good engine to see if it is also the same before taking anything apart.That WOT also seems low to me.Are you sure you have a good base engine might be time to do a cylinder power balance and compression check.You can also compare fuel presure readings to the good engine.If your not testing fuel pressure when the problem occurs then the test is meaning less.
  9. #9
    Nov 2021
    8
    Thanks, I agree doesn't sound like a base idle issue but still may look into it. When it stalls, it's a slow RPM drop from idle which would make me believe it's a fuel problem. I compared the computer readings from both engines by charting each sensor side by side. All readings are so close to each other so I don't see a problem. Vacuum remains at 14.7-15 as I am told is a little low. I need to check / replace the gasket adaptor to intake just to be safe. I'll take a look again comparing the vacuum readings between the engines with a test gauge. I don't remember a big difference but well worth re-checking. Start / running fuel pressure similar between the engines but the problem engine is a bit erratic at times at hot start. I know that's not good. Could air in the fuel system be a cause although I have no clue where it could be coming from with all the new parts and switching TB and ECU from the other engine. Keep in mind the port engine continues to run great even with the changing out.
  10. #10
    Apr 2018
    NW chicago area
    22
    I agree it is starting to sound like a fuel issue assuming the engine is mechanically sound.Dont think you should throw any more parts at it until you have more clues on which direction to go.It is possible its sucking air in the fuel system but would have to be before the pump other wise it would be a fuel leak because everything after the pump is pressurized. Maybe a vapor lock issue but without the other engine doing it I doubt it.Something you can try is when problem occurs is pump the throttle and see if you can keep it running and eventually get it to idle.The reason I say that is because the TBI system is programmed to add a extra squirt of fuel each time the throttle is advanced quickly when running to act just like a accelerator pump.If you can keep it running by doing this and can get it to eventually idle I would definitely say its a fuel delivery problem.You can also try turning the ignition on and off several times and pausing 10 to 15 seconds between each cycle when problem occurs to activate fuel pump several times to purge fuel system and build pressure and see if that effects problem.
  11. #11
    Nov 2021
    8
    Throttle idea, never tried the quick pump just a slight advance. Interesting thought! I have tried the key on-off before with little success on start. For me the next thought doesn't make sense but I'll throw it out anyway. Even though it sits for a week, starts and runs great for hours at all RPM, any chance I have a tank "pick-up" tube issue causing the possible air prior to the pump?
  12. #12
    Apr 2018
    NW chicago area
    22
    Any thing is possible at this point.Can you leave the fuel presure gage on the engine to see what it reads when problem is acting up.If you did have an air leak I would suspect it be at the tank selection valve as that has moving parts and seals that may be effected by heat.The key to finding your next step is when problem is acting up are you loosing fuel or spark.
  13. #13
    Nov 2021
    8
    Yes, I've exhausted everything I felt or found to be under spec. The first time it wouldn't start and found no fuel pressure, the first new pump and tank supply line was replaced which was suspect of being the problem. After than it's been piece by piece replacement or checking of associated parts which could be a caused the problem including the parts swap with the sister engine. We have also vacuumed check with test gauge and along with pressure gauges, use of the computer engine data hunting for the problem. Each part replaced was then sea trailed to test our theory. I did lose the spark one time; the distributor mag pick-up had failed. I believe it was from testing the fuel pump and system and not starting the engine caused it to overheat. I would think if it was a heat related electric or spark issue the engine would give an indication of a problem during a long sea trail. It just runs excellent! To pull the tank pickup tube will require some cutting of the floor and interior wall. Just haven't found anything that could be a problem externally, but may not have any choice. I neglected to add the fact, always had at least 1/4 tank of gas but did fill to over 3/4 (I can use a stick into this side fill to verify) without any engine change. I will try everyone's suggestion! But it's due to be pulled for the winter, so it's going to be a long winter with this problem driving me crazy! And just think, haven't had a problem with the port engine, which may be next! (Hope not!) I really appreciate all the help I been given and hope I can help someone else on the forum. Please keep your thoughts coming, for everything must be will be looked at to resolve this problem so I can get the reliability back in this engine next season!
  14. #14
    Apr 2018
    NW chicago area
    22
    If your loosing fuel pressure don't overlook the electrical side.I have seen many relays and connections act up at certain temps and I always carry a couple spare relays.It would be very easy to hook up a indicator light to see if your loosing power to fuel pump which it sounds like you are if you had zero fuel pressure when it happend.If it is a relay I would suggest getting the number off the relay and only get an ac delco also the same ones on the truck tbi systems.The china electrical components rarely work very long and cause other problems.
  15. #15
    Nov 2021
    8
    I've replaced the relays from a Crusader dealer, but I didn't take notice if it was an AC Delco. Could have been re-packaged, that's a good question I need to verify. A wired-in indicator light is a great idea. Thanks! Relay problems! Four years ago, my port engine began to "break-up and wouldn't go over about 2800 RRPM. Long story short, my son has a multi-meter with a digital screen for graphing. Went out for sea trail with it and the computer hooked up, after several runs, he had me stop and shut-down. Found the meter display graphed erratic voltages from 14.5 to 6 volts which caused the computer RPM to show over 2800 to 8,000 RPM. So, the ECU was reading "Over RPM" and cutting the ignition to "protect the engine" although RPM was only 2800 or less. Answer: "chattering ignition relay!! Replaced it and it resolved the RPM problem. Never would have found it without that specialized meter other than replacing a bunch of parts. My meter is a good one and I couldn't find a voltage problem with it. So always keep in mind they may cause big problems! Thanks again!
  1. Crusader 454XL running HOT at cruising, not at idle. Help!
    By wellcraft33 in forum Crusader Marine Engine Forum
    Last Post: 03-04-2015, 08:38 PM
  2. Hoping for a little help on a Crusader 454XL
    By Ply in forum Crusader Marine Engine Forum
    Last Post: 11-28-2014, 04:17 PM
  3. 454 crusader starting problem
    By pete smith in forum Crusader Marine Engine Forum
    Last Post: 08-11-2012, 10:37 PM
  4. Crusader 8.1L Starting problem
    By boomerfishing in forum Crusader Marine Engine Forum
    Last Post: 06-12-2010, 03:26 PM
  5. Crusader 454XL oil pan
    By flyboyo2 in forum Crusader Marine Engine Forum
    Last Post: 09-23-2009, 09:23 PM
