He called me back, said the only other person who looked at it passed & he didn’t work something out with someone who said they had a tiller handle.
The Good
Its actually a ‘74 (6403C) long shaft. 6HP
I picked it up for $50 CDN, about $35 USD.
Got into it today. No water in gear oil, just grungy.
Compression both jugs 95 psi. Gaskets look,original hasn’t been apart.
Impeller looks new, is very flexible, SS plate & metal pump housing, no scoring, everything came apart easy.
Drive shaft has no corrosion, & came out of crank shaft.
Pulled the flywheel- coils look new.
The bad
no spark on top cylinder
Didn’t have time to investigate further than looking at coils.
bottom end paint is in poor shape, like you see when they sit in the water all season, at least if was fresh water.
Damned near lost the little “T” fitting that drives the impeller, luckily found it, they want $9 for that tiny bit of metal.
