Results 1 to 17 of 17
    Default Heat Sink & Diode
    What does the heat sink and diode do?
Name:	Heat sink & diode .jpeg
    Nov 2011
    3,421
    Default Re: Heat Sink & Diode
    Along with the other pair, they form a full wave bridge rectifier. In plain-speak, they convert the AC alternator output to DC for charging the battery.
    Yes, I see the other part on the diagram. How do. you know if they're bad and how do you test them?
    Sep 2010
    22,796
    Must be on a mid 1960's V-4 motor.---
    Sep 2010
    22,796
    Must be on a mid 1960's V-4 motor.---Is your motor not charging ?----Tested the stator windings?
  6. #6
    It's charging but how high should the voltage range be at the battery?
  7. #7
    Sep 2010
    22,796
    Around 13.5 / 14 volts at a fast idle.----Model # of your motor ?------Those 2 diode parts are cheap.-----Might not hurt to have spares on hand.----Your location ?
  8. #8
    Mind will jump from low 12's to 16's. Is this too high?
    It's a 1966 80hp Johnson. model V$AL-18.
  9. #9
    Sep 2010
    22,796
    Perhaps the voltage regulator is the issue.
  10. #10
    How do I test the voltage regulator?
  11. #11
    Nov 2011
    3,421
    You know the diodes are good because it obviously is charging. Besides, that type was very durable.
    Voltage regulator: From the factory service manual: With the solid state regulator, there can be only two types of failure, under (no) charging or overcharging. Run motor at least 20 minutes to stabilize the regulator. Then with motor running 2000 RPM and all accessories off, check the voltage at the regulator red wire. If the voltage is in excess of 15 Volts, the regulator should be replaced.
  12. #12
    Thanks for the info. If I find the regulator is bad what are your suggestions for a replacement?
    I see some nos ones on Ebay and a CDI one like the one pictured.
    Name:  CDI Regulator .jpeg
  13. #13
    Nov 2011
    3,421
    Since it's been probably 50 years since I've had occasion to replace one, I don't have an up-to-date preference.
  14. #14
    Thanks fdgator. I'll do some research on CDI Electronics. Maybe someone here can reply with their experiences with a CDI regulator.
    I'll let you know what I find out.
  15. #15
    Looking at the wiring diagram the red wire runs to the ignition switch. Do I check voltage at the ignition switch?
  16. #16
    Nov 2011
    3,421
    The book is sort of confusing. In one place it says to check voltage at regulator. another place simply says "check battery voltage".
  17. #17
    Nov 2011
    3,421
    You got me pondering on this one. Studying the system and how it works, the regulator is monitoring the voltage on the red wire as it is presented to the regulator input. Therefor, it should be measured at the regulator red wire, as instructed and shown in the picture. If it "sees" more than 15V at that location, it should cut back on alternator output. Measuring it anywhere else introduces the possibility of error due to other possible faults. Now to relax my brain awhile. Whew!
  1. Ready to sink the boat
    By Junior78 in forum Identifying Model / Year / Horsepower
    Last Post: 07-29-2019, 10:57 PM
  2. Will a f115 sink me?
    By Alluvium in forum Yamaha Outboard Forum
    Last Post: 10-28-2014, 09:40 AM
  3. How does this sink work?
    By footbrake in forum Boat Plumbing Systems
    Last Post: 06-21-2013, 04:12 AM
  4. Replies: 2
    Last Post: 03-31-2011, 08:45 AM
  5. Help need with my sink
    By letsrock in forum Miscellaneous marine engine topics
    Last Post: 08-21-2008, 01:28 PM
