Well then, you're in for an experience when you see one aren't you!
It's not just the gasket that can fail. A "salty" will often corrode where the gasket needs to seal around the cylinder OD. This can happen on the block side, or the head side, and it's NOT that unusual, especially for high time engines run in salt water.
So if you want to split hairs, technically it may not actually be a gasket failure, but instead be a head or block failure. The bigger point though, is you aren't going to see it until you pull the head!
There's also the potential for an engine to really get cooked. Maybe to the point the plastic valve cover melts. Something like this can make the gasket brittle, and even if all seems OK after replacing the reason it was cooked, it can fail in the next few hours of operation.
This I NOT something you're going to see in a well maintained fleet of motors, as anyone worth their paycheck is going to eliminate at least most of the potential for one of these to overheat, right?
On top of the potential for engines having issues in the gasket area, there's also potential for them to corrode to the point where (salt) water is allowed to get into many other areas of the engine, and many/most will be visible with the removal of the head....
Point being, if you've never seen any of this in your fleet, stick around a while longer.... I can assure you it DOES happen!
-Al
Just a shade tree mechanic.....
