My Mercury 150 at times runs hot but not hot enough to set the warning off. I have replaced the water pump, thermostats and poppet valve. Now I have no water coming out the tell tail. According to this flow graph in the manual it shows that the water has to go through the thermostats before it comes out the tell tail. Can someone explain to me how this is suppose to work because I know the thermostats haven't reached 140 degrees, to open within seconds of the motor having been started. If I can understand how the water flow is suppose to work, hopefully I can diagnosis the issue with my motor.
