1/2 a Mechanic
Hello All... I am new to forum stuff and need advice. I have a 1988 Evinrude 60 HP E60TLCCR motor with the VRO removed and a standard fuel pump in it's place. This was done when the power head was replaced 6 years ago, My motor ran like a champ for 6 years then all of a sudden started to stall out. When it would start it would run fine at high rpm's but stalls at idle before I can get it into gear. Because the motor is old and many electrical parts are believed to be original I replaced the fuel pump, power pack, plug wires, plugs, solenoid and starter. None of that fixed the problem. A marina rebuilt all three carburetors and swapped out the new fuel pump for a VRO premix replacement this last week. Again that did not solve the problem. I had them put my new fuel pump back on the motor, paid my bill and took my pontoon home disappointed. The motor (when it will start) runs great at high rpm but again will not idle. The marina had problems with starting and running if the boat motor is on a angle (tilted up a bit on muffs or inclined at the boat launch. Does anyone know what the heck is wrong with my motor and how to fix it????? Please help.... Thanks' 1/2 a mechanic.
