1985 Force 85 HP no spark HELP!!!
Bigbigb
My 1985 Capri 85 HP start and run fine but the middle cylinder has no spark, I swap the coil with bottem cylinder and it has spark so I know that coil is good how do I check cdi module Thank you
Change the packs around.
The no spark on #2 will end up with nothing hooked to #2 and the change should make it spark.
The trigger leads are very thin and break easily under the shrink wrap.
IF??? you doubt anything??? I'd change ALL the connectors just to be sure.
As you go, mark each wire and take pics.
I test the spark by pull the spark plug wire one by one to see which cylinder dose not work will it hurt the ignition system
Not usually. The best way is a tester grounded. Either one of the pictured testers.
shopping
shopping
outboardignitiondotcom has test procedures for your motor.
Before buying another part, I'd look into testing the components you have.
