Here's what I've got, oil pressure is initially within acceptable ranges (around 30psi at idle and 60-70 at 2500-3000rpms). When I get on plane and am going about 25mph (2500rpms) it will initially go for about 5min and then the low pressure (continuous) alarm sounds, green oil pressure light goes out, and guardian mode kicks in. I shut down the motor and restart. Pressure returns to normal. I can get about two minutes within 2500rpms before it repeats and if I hit hard and go up to 3000-4000 the alarm goes almost immediately.
I ran it with a pressure gauge attached and noticed that while pressure look good at the start it will gradually decrease to around 30-40 (while at higher rpm) until the alarm sounds.
interventions:
Changed oil & filter multiple times
Replaced both high & low pressure sensors (prior to running with the gauge and realizing it was a gradual pressure drop)
I'm a bit stumped on this one. I had rebuilt the motor prior to these issues and know all the bearings are in proper tolerances. I'm not familiar with the oil flow path so I'm lost as to why the pressure would be gradually dropping. it never drops below 25-30psi at idle which makes my believe the pump is fine.
Would a worn pressure valve spring or a clogged valve spool filter attribute to any of these symptoms?
Any ideas would be appreciated I'm chasing a dragon at this point.
interventions:
