merc200dalarna
At full throttle (or even at 2/3- cruising on plane) my motor has a tendency to intermittenly 'drop off'
Hard to explain, feels like fuel starvation.
It sort of 'alternates' between pushing hard, and dropping off for half a second, then pushing again for like 5 seconds and so on...
I have started to look at videos of 'injectors' and the 'VST' plus the many filters along the way.
And I have now learned that I should drain VST for winter.
I run on high quality '98 octane' european gas (5% ethanol)
Incoming fuelfilter was replaced this spring, no clogging or unusal debris.
New sparkplugs this spring.
I've had this issue and tried to use fuel additives like injector cleaner and quiksilver stabilizer, has sort of worked, or perhaps imagined to work..
Should I try to pull VST and check filter at HP-Pump? Plus clean out bowl and needle?
Or?
Or?
